Device OS 1.0.1-rc.1 Release Candidate is out on the Web IDE for (Core/Photon/P1/Electron)
released on February 4th, 2019
:white_check_mark: This 1.0.1-rc.1 Release Candidate will be defaulted to 1.0.1 on Feb. 18th, 2019 unless there are regressions found that require further patches. :pencil: Testing on your applications is encouraged and appreciated, thank you! :person_bowing:
Note: This is a Release Candidate (RC) and is not intended for production yet. We've tested this RC to the best of our ability and we want to know what you think now! Please understand that some care and attention is necessary when testing this RC, and be sure to upgrade to the final release when it's available. This RC will not be available by default. To use you must select the version dropdown from the devices drawer. Downgrading back to the current release info is at the bottom of this post.
  4. Then update to 1.0.1-rc.1
  • You may update to 1.0.1-rc.1 directly first, flash the system firmware (attached above) in order 1,2(,3) to the device using particle flash --usb <system-part.bin>. See the next note about the bootloader if you are offline!
Note: P1/Photon Bootloader
The Cloud will automatically update the bootloader on P1/Photon devices if your device is online. If your device does not connect to the cloud and it is offline, you should flash the bootloader to the device using particle flash --serial <bootloader.bin>. This should be done after upgrading system firmware. The Electron bootloader is applied automatically from it's own system parts.
1.0.1-rc.1
BUGFIXES
  • [LTE/Electron] Fixes software Timer()'s halting after millis() overflows (every 49.7 days) #1688
  • [LTE/Electron] bug fixes and enhancements (see PR ->) #1689
INTERNAL
  • Fix Travis badge #1670
  • Mojave doesn't ship with wget #1674
  • Bypass git dependency in build #1664
  • Refactor release scripts #1687
System Binaries (all devices)
Release v1.0.1-rc.1 (Core/Photon/P1/Electron) ยท particle-iot/device-os ยท GitHub
Programming and Debugging
