So i’m trying to connect my particle core to blynk and it doesn’t detect it, it detected it before but now it doesn’t
could it be that i fried a component in my particle core?
I can still flash code to it so i don’t know
the problem happened when i connected 2 3.6V 2500mA batteries (making 7.2V together) to my core
It was working for a bit and then it stopped connecting to it
any help would be appreciated
@Zilian, hooking 7.2v to the Core’s Vin (I assume) would most likely damage the onboard LDO regulator which has a maximum input voltage of 6v. Does the core power up via USB?
Your only alternative besides replacing the regulator is to power the core directly via its 3.3v power pin with ONLY 3.3v (!). You should try this before declaring your Core officially dead.
@zilian, if the Core runs with USB then that is good news! Your Core may not be damaged. Try flashing Tinker to your Core to see if it connects to wifi and the cloud. If that works, then you can go from there with Blynk.
