Today I tried working with I2C on the core, I used a Grove I2C Motor Driver, But nothing seems to be happening… I tried the motor driver with a arduino and it seems to work fine. I’m not sure what I am doing wrong…
Here is the code I used -
#define MotorSpeedSet 0x82
#define PWMFrequenceSet 0x84
#define DirectionSet 0xaa
#define MotorSetA 0xa1
#define MotorSetB 0xa5
#define Nothing 0x01
#define EnableStepper 0x1a
#define UnenableStepper 0x1b
#define Stepernu 0x1c
#define I2CMotorDriverAdd 0x0f // Set the address of the I2CMotorDriver
// set the steps you want, if 255, the stepper will rotate continuely;
void SteperStepset(unsigned char stepnu)
Wire.beginTransmission(I2CMotorDriverAdd); // transmit to device I2CMotorDriverAdd
Wire.write(Stepernu); // Send the stepernu command
Wire.write(stepnu); // send the steps
Wire.write(Nothing); // send nothing
Wire.endTransmission(); // stop transmitting
// Enanble the i2c motor driver to drive a 4-wire stepper. the i2c motor driver will
//driver a 4-wire with 8 polarity .
//Direction: stepper direction ; 1/0
//motor speed: defines the time interval the i2C motor driver change it output to drive the stepper
//the actul interval time is : motorspeed * 4ms. that is , when motor speed is 10, the interval time
//would be 40 ms
void StepperMotorEnable(unsigned char Direction, unsigned char motorspeed)
Wire.write(EnableStepper); // set pwm header
Wire.write(Direction); // send pwma
Wire.write(motorspeed); // send pwmb
//function to uneanble i2C motor drive to drive the stepper.
void StepperMotorUnenable()
Wire.write(UnenableStepper); // set unenable commmand
//Function to set the 2 DC motor speed
//motorSpeedA : the DC motor A speed; should be 0~100;
//motorSpeedB: the DC motor B speed; should be 0~100;
void MotorSpeedSetAB(unsigned char MotorSpeedA , unsigned char MotorSpeedB) {
MotorSpeedA=map(MotorSpeedA,0,100,0,255);
MotorSpeedB=map(MotorSpeedB,0,100,0,255);
Wire.write(MotorSpeedSet); // set pwm header
Wire.write(MotorSpeedA); // send pwma
Wire.write(MotorSpeedB); // send pwmb
//set the prescale frequency of PWM, 0x03 default;
void MotorPWMFrequenceSet(unsigned char Frequence) {
Wire.write(PWMFrequenceSet); // set frequence header
Wire.write(Frequence); // send frequence
Wire.write(Nothing); // need to send this byte as the third byte(no meaning)
//set the direction of DC motor.
void MotorDirectionSet(unsigned char Direction) { // Adjust the direction of the motors 0b0000 I4 I3 I2 I1
Wire.write(DirectionSet); // Direction control header
Wire.write(Direction); // send direction control information
void MotorDriectionAndSpeedSet(unsigned char Direction,unsigned char MotorSpeedA,unsigned char MotorSpeedB) { //you can adjust the driection and speed together
MotorDirectionSet(Direction);
MotorSpeedSetAB(MotorSpeedA,MotorSpeedB);
void stepperrun()
Serial.println("sent command to + direction, very fast");
SteperStepset(255);
StepperMotorEnable(1, 1);// ennable the i2c motor driver a stepper.
delay(5000);
Serial.println("sent command to - direction, slow");
SteperStepset(255);
StepperMotorEnable(0, 20);
delay(5000);
Serial.println("sent command to - direction, fast");
StepperMotorEnable(0, 2);// ennable the i2c motor driver a stepper.
delay(5000);
Serial.println("sent command to + direction,100 steps, fast");
SteperStepset(100);
StepperMotorEnable(1,5);
delay(3000);
Serial.println("sent command to shut down the stepper");
StepperMotorUnenable();
delay(1000);
Serial.println("sent command to - direction, slow, and 10 steps then stop");
SteperStepset(10);
StepperMotorEnable(0,40);
delay(5000);
delay(5000);
Wire.begin(); // join i2c bus (address optional for master)
delayMicroseconds(10000);
Serial.println("setup begin");
stepperrun();
while(1) {
MotorSpeedSetAB(100,100);
delay(10); //this delay needed
MotorDirectionSet(0b0110); //0b1010 Rotating in the positive direction
delay(10000);
MotorDirectionSet(0b1001); //0b0101 Rotating in the opposite direction
delay(500);
