I am moving a project onto Photon which contains many separate .cpp files. I have set up a project structure including libraries. When I run “particle compile photon”, the compilation stops due to an error in the code, but the compiler output with the error is not shown.
Is there a way to get all of the compiler output?
For example, here the error stopping compilation is not shown.
In file included from src/ui.cpp:4:0:
lib/Adafruit_SSD1305/src/Adafruit_SSD1305.h: In constructor ‘Adafruit_SSD1305::Adafruit_SSD1305(int8_t, int8_t, int8_t, int8_t)’:Compile a source file, or directory using the cloud compiler
Usage: particle compile [options] [files…]
