# Particle-cli Update
**URL:** <https://community.particle.io/t/particle-cli-update/27512>\
**Created:** [November 25, 2016, 8:20pm UTC](https://community.particle.io/t/particle-cli-update/27512 "2016-11-25T20:20:52Z")\
**Showing post:** 2
**Author:** ![Moors7](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/moors7/32/588_2.png) [@Moors7](https://community.particle.io/u/Moors7)\
**Post date:** [November 25, 2016, 8:36pm UTC](https://community.particle.io/t/particle-cli-update/27512/2 "2016-11-25T20:36:38Z")
It seems as though you’ve got two separate versions installed. Personally, I’d remove both, then use the auto-installer for Windows. That should also auto-update it in the future 😄 If you don’t want to use the auto-installer, then still remove both, and install it from the Windows command prompt, rather than the node.js one.
_[View the full topic](https://community.particle.io/t/particle-cli-update/27512)._
