If you are using Linux and updated your Particle CLI version to 3.52.2, you should update again.
With CLI version 3.52.2, every Linux standalone binary (x64, arm64, armv7) failed on startup with the error:
$ particle
The Particle CLI requires Node >=22.20
This did not affect Windows and Mac.
The Linux CLI does not auto-update, so you'll need to update again to get version 3.52.3:
bash <(curl -sL [https://particle.io/install-cli](https://particle.io/install-cli)
