Installing new driver worked as you see below but Photon LED is blue and not blinking. I reset it and now it’s blinking yellow.
Your environment has been set up for using Node.js 0.12.7 (x64) and npm.
C:\Users\Amir>particle identify
Your device id is 210027000647343232363230
C:\Users\Amir>particle setup wifi
? Should I scan for nearby Wi-Fi networks? (Y/n) y
? Should I scan for nearby Wi-Fi networks? Yes
? Select the Wi-Fi network with which you wish to connect your device: (Use arro
? Select the Wi-Fi network with which you wish to connect your device: ATT241
? Security Type: WPA2
? Wi-Fi Password: 8561898849
Attempting to configure Wi-Fi on COM5
I said: w
Serial said: SSID:
I said: ATT241
Serial said: ATT241
Security 0=unsecured, 1=WEP, 2=WPA, 3=WPA2:
I said: 3
Serial said: 3
Password:
I said: 8561898849
Serial said: 8561898849
Thanks! Wait while I save those credentials...
Done! Your device should now restart.
It seems I misinformed you. I can not make it breath it BLINKS only. The color is bluish not redish. Probably it does not go to safe mode. Your vibe video is so short that neither the color nor it’s behavior is understandable. Please make a video guide to explain complex troubleshooting process.
I did it 3 hours ago and installed the new tinker app too. Please check my previous posts. Then I used mobile app. Everything was fine until the last step: couldn’t claim Photon!
C:\Users\Amir>particle serial identify
C:\Users\Amir>particle device add 210027000647343232363230
Claiming device 210027000647343232363230
Failed to claim device, server said { ok: false, errors: [ 'Device is not conne
cted' ] }
