For this handler, how is the out of memory calculated? I tried searching within github, but I couldn’t find it.
System.on(out_of_memory, outOfMemoryHandler);
Is it calculated to something like this?
void fragmentationCheck() {
static uint32_t prevFragCheckMillis = 0;
static uint32_t prevFragPublishMillis = 0;
static uint32_t freeMemory = 0;
static uint32_t largestBlock = 0;
static float fragmentationPercent = 0;
static bool runAtStartup = true;
if ((millis() - prevFragCheckMillis > (60000 * 60)) || runAtStartup) {
runtime_info_t info;
memset(&info, 0, sizeof(info));
info.size = sizeof(info);
HAL_Core_Runtime_Info(&info, NULL);
largestBlock = info.largest_free_block_heap;
freeMemory = System.freeMemory();
fragmentationPercent = ((1 - ((static_cast<float>(largestBlock)) / freeMemory)) * 100.0);
// Serial.print("largestBlock : ");Serial.print(largestBlock);
// Serial.print(" freeMemory : ");Serial.print(freeMemory);
// Serial.print(" fragmentationPercent : ");Serial.println(fragmentationPercent);
char memoryCharArray[80];
snprintf(memoryCharArray, sizeof(memoryCharArray),
"%u.%u.%.2f.%u"
, largestBlock
, freeMemory
, fragmentationPercent
, Time.now()
if (millis() - prevFragPublishMillis > (24*60*60*1000)) { // publish every 24 hours
#if PLATFORM_ID == PLATFORM_ELECTRON_PRODUCTION
publishAsync("fragInfo", memoryCharArray);
#elif PLATFORM_ID == PLATFORM_P1
if (Particle.connected() && WiFi.ready()) {
Particle.publish("fragInfo", memoryCharArray, 60, PRIVATE);
#endif
prevFragPublishMillis = millis();
if (fragmentationPercent > 50.0) { //reset device if too fragmented
publishAsync("fragRst", memoryCharArray);
Particle.publish("fragRst", memoryCharArray, 60, PRIVATE);
#endif
delay(2000);
System.reset();
runAtStartup = false;
prevFragCheckMillis = millis();
The out of memory handler happens when a memory allocation (malloc, new, strdup, etc.) fails. This occurs whenever the largest free block if smaller than the allocation request size, regardless of how much is available in total.
