+1 on @ninjatill's response :
The I2C adapter shield is by far the easiest and cleanest method.
Hi Gang. Got my sensor board in from NCD. So for hook up I have a few questions as I’m new to I2C:
I’m going to be cutting off one of the connectors on the supplies cable and wiring into a solder breadboard that the Particle is on (see photos).
Questions:
THANKS!
Unless you have other pull-ups you need them. I2C always requires them.
Not sure about that. The board description says it's a 5V sensor, so 3.3V may not suffice. You could use a boost converter to get 5V out of the 3v3 pin.
