# Noob: Turn on/off LED at 8:00AM
**URL:** <https://community.particle.io/t/noob-turn-on-off-led-at-8-00am/2861>\
**Category:** Getting Started\
**Created:** [February 14, 2014, 9:11pm UTC](https://community.particle.io/t/noob-turn-on-off-led-at-8-00am/2861 "2014-02-14T21:11:17Z")\
**Showing post:** 2
**Author:** ![Dave](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/dave/32/181_2.png) [@Dave](https://community.particle.io/u/Dave)\
**Post date:** [February 14, 2014, 9:27pm UTC](https://community.particle.io/t/noob-turn-on-off-led-at-8-00am/2861/2 "2014-02-14T21:27:32Z")
Hi @sweenig,
You're in luck! A bunch of community members ported Network Time syncing code to run on the core, and I recently made a blink an LED example using their code. I posted that here:
> **[How to toggle a digital pin](https://community.particle.io/t/how-to-toggle-a-digital-pin/2797/8)**
> I was totally serious, here’s a version that syncs the clock with an NTP server, and then blinks on 5 second intervals (code from this thread! https://community.spark.io/t/getting-utc-time-from-ntp-server/1213/3 - Thanks! ) UDP UDP; char string\[...
This program blinks on every multiple of 5 seconds synced with a time server, it should be a small step to port that to blink at 8am. 🙂
Thanks,
David
_[View the full topic](https://community.particle.io/t/noob-turn-on-off-led-at-8-00am/2861)._
