I’ve been tinkering around with an Electron for a few months. I have the GPS Asset Tracker shield and am trying to follow @Dave’s GitHub project for the Fancy Asset Tracker. I’m familiar with Ardunio’s, but feeling a little overwhelmed at the level of CLI knowledge this seems to require. I’ve tried downloading all the necessary libraries into my project folder, but get a slew of error messages along the way.
Can anyone give me some encouragement as to how to get the GitHub repo downloaded and onto the device? Thanks a bunch in advance.
Thanks for the prompt response @nrobinson2000. Still a little lost on the build and flash components. I see the scripts, but do I need to edit them to point to the correct example? Feel like I’m 90% of the was through understanding. Just searching for a breakthrough
Thanks @Dave. I think I’m learning a ton this afternoon. First time working with a development on any board via the command line. I’ve saved the GitHub repo to /Particle/projects. I’m just getting a ton of “No File or Directory exists” errors.
I know this is very basic and elementary stuff, just can’t crack it.
You should be in the root of the project directory when building. Alternatively, you can just copy all the project and lib files into a folder and compile that folder. The build script is trying to do just that:
# there's a place for us
mkdir temp_build
# remove any previous builds
rm `basename $1`.bin
rm temp_build/*.*
cp $1/*.* temp_build
# copy over my favorite stuff
cp gps-library/*.h temp_build
cp gps-library/*.cpp temp_build
# try to compile it with the CLI
particle compile electron temp_build --saveTo `basename $1`.bin
Try doing these steps line by line on the command line, and see where things go wrong. Maybe you’re not in the right terminal environment, or things aren’t checked out, or you’re missing some piece?
