Hi. I’ve been at this for a few hours now. It seems I’m unable to detect my core at all. When using the app, the core continues to flash blue and eventually the app returns a message of “No cores found”. I then tried to use CoolTerm on my mac, it tells me that the port my spark is connected to is disconnected. I tried factory resetting it as well to no avail.
I too experienced this 2-3 times, but after factory resetting everything was fine and I was able to configure the WiFi.
I just tried factory resetting it again. No luck
[Solved-ish] I managed to connect it using my friends phone to the same wi-fi network that I had been previously attempting on. It seems there may be some issue with trying to connect with a galaxy s4 or kit kat os.
I have a galaxy S4 but not kit kat… so maybe it’s the issue but yeah…
You mught want to try again if you wish since it should work
Actually, I have a Galaxy Note 3 with Kit Kat and it works every time while my IOS 7 tablet does not
