# New Xenon, and Spectra Xenon stuck in Listening, no USB serial
**URL:** <https://community.particle.io/t/new-xenon-and-spectra-xenon-stuck-in-listening-no-usb-serial/46329>\
**Created:** [December 16, 2018, 4:01am UTC](https://community.particle.io/t/new-xenon-and-spectra-xenon-stuck-in-listening-no-usb-serial/46329 "2018-12-16T04:01:39Z")\
**Showing post:** 10
**Post date:** [December 26, 2018, 6:56pm UTC](https://community.particle.io/t/new-xenon-and-spectra-xenon-stuck-in-listening-no-usb-serial/46329/10 "2018-12-26T18:56:52Z")
> [@Zonker](#):
> I set up my #1 and #2 boards at Spectra
That's an important piece of info. If you are updating an Argon from anything before rc.25 to rc.25 or above, you also need to update the NCP (Network CoProcessor).
For that you need to download these files
- [https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/system-part1-0.8.0-rc.27-argon.bin](https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/system-part1-0.8.0-rc.27-argon.bin)
- [https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/tinker-serial1-debugging-0.8.0-rc.27-argon.bin](https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/tinker-serial1-debugging-0.8.0-rc.27-argon.bin)
- [https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/bootloader-0.8.0-rc.27-argon.bin](https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/bootloader-0.8.0-rc.27-argon.bin)
- [https://github.com/particle-iot/argon-ncp-firmware/releases/download/v0.0.5/argon-ncp-firmware-0.0.5-ota.bin](https://github.com/particle-iot/argon-ncp-firmware/releases/download/v0.0.5/argon-ncp-firmware-0.0.5-ota.bin)
And then you need to perform these commands in order
In DFU Mode (blinking yellow)
```plaintext
particle flash --usb system-part1-0.8.0-rc.27-argon.bin -v
particle flash --usb tinker-serial1-debugging-0.8.0-rc.27-argon.bin -v
In Listening Mode (blinking blue)
```plaintext
particle flash --serial bootloader-0.8.0-rc.27-argon.bin -v
particle flash --serial argon-ncp-firmware-0.0.5-ota.bin -v
For the Xenon you do respectively
- [https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/system-part1-0.8.0-rc.27-xenon.bin](https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/system-part1-0.8.0-rc.27-xenon.bin)
- [https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/tinker-serial1-debugging-0.8.0-rc.27-xenon.bin](https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/tinker-serial1-debugging-0.8.0-rc.27-xenon.bin)
- [https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/bootloader-0.8.0-rc.27-xenon.bin](https://github.com/particle-iot/firmware/releases/download/v0.8.0-rc.27/bootloader-0.8.0-rc.27-xenon.bin)
```plaintext
particle flash --usb system-part1-0.8.0-rc.27-xenon.bin -v
particle flash --usb tinker-serial1-debugging-0.8.0-rc.27-xenon.bin -v
```plaintext
particle flash --serial bootloader-0.8.0-rc.27-xenon.bin -v
> [@Zonker](#):
> (unclaim and claim again?)
You shouldn't need to unclaim/reclaim the devices, you can just set them up as if they were new, even if they are already claimed to your account.
_[View the full topic](https://community.particle.io/t/new-xenon-and-spectra-xenon-stuck-in-listening-no-usb-serial/46329)._
