Need help communication between particle and openframeworks
photon
Tags: #<Tag:0x00007fe21e79f420>
#1
Hi there,
I’ve been attempting to send data between my particle photon and openframeworks recently but I’ve had no luck. I was looking to see if anyone has achieved this in the past or if there is a method of connecting the two using particle.publish and particle.subscribe functions. Any help or guidance anyone could offer would be greatly appreciated.
Cheers
#2
Welcome - generally quicker to search the forum first …
See if some of these threads haven’t solved the problem already ?
#3
Hi there,
Thanks for the response! I’ve taken a look at all of those posts already but none of them really achieve what I’m wanting to do
#4
Then you will need to post some code so the forum can comment and let you have suggestions. It is impossible to guess what you want to achieve from this description
