MyWeatherstation for indoor & outdoor use
Check the current conditions: light, temperature, humidity on your smartphone (Blync), online (thingspeak) and get informed in case of problems (IFTTT).
Follow my circuit at: https://www.hackster.io/ingo-lohs/myweatherstation-for-indoor-outdoor-use-8c6a70
@Postler, well done! I noticed that you have a number of subscriptions setup for your webhook responses but the handler (myHandler()) does nothing. I’m assuming that’s because the webhooks are firing data to Thingspeak. You may want to add comments to that effect. :wink:
