Multiple DS18B20 with Photon
#129
Thanks @BulldogLowell, I see you are with me!
I guess that’s right, but I am so happy with @Ric’s solution that I would prefer to refine that one further with CRC checking rather than to try all over again starting with another library. Let me know if you don’t agree and which one gives us a better solution… :wink:
Concerning the extra “filtering” needed:
I remembered another exercise with @Ric, developing a “filtering method”: LINK
Probably that’s an even better way than my previous idea…
What do you think?
:sleeping:
#130
Do you mean with arrays?
More simplification would be great, but usability is more important for my applications. The requirements in my earlier post are vital!
:sleeping:
#131
sounds like the gauntlet has been thrown… I’m sure @Ric is up to the task.
I’d create a struct like this for the pairs of sensors:
struct Zone{
    byte highAddress[8]; // high sensor
    byte lowAddress[8];  // low sensor
    double highTemp;
    double lowTemp;
    double averageTemp;
    double energy;
void doSomethingWith(Zone* zone);
and an array of those objects like this:
Zone tempSensor[]{
    {{0x28,0xFF,0x0D,0x4C,0x05,0x16,0x03,0xC7}, {0x28,0xFF,0x25,0x1A,0x01,0x16,0x04,0xCD}},
    {{0x28,0xFF,0x89,0x19,0x01,0x16,0x04,0x57}, {0x28,0xFF,0x21,0x9F,0x61,0x15,0x03,0xF9}},
    {{0x28,0xFF,0x16,0x6B,0x00,0x16,0x03,0x08}, {0x28,0xFF,0x90,0xA2,0x00,0x16,0x04,0x76}}
you can assign names to them as you did in @Ric 's code:
Zone* Tank1 = &tempSensor[0];
Zone* Tank2 = &tempSensor[1];
Zone* Tank3 = &tempSensor[2];
Zone* myTanks[] = {Tank1, Tank2, Tank3};
then call a function on the objects:
for (auto& eachTank : myTanks)
    doSomethingWith(eachTank);
maybe a bit tricky to grasp, but there are (in this example) three tank objects each that retain two temperatures, their average and the energy… kind-of-thing.
#132
I might be in a couple of days, but I don’t want to try to write code on my phone ( I’m in Yosemite park right now).:wink:
#133
I guess you are not targeting a system version greater 0.5.2 in Web IDE.
#134
I was targeting v0.6.2
Should I aim lower?
#135
Sounds interesting, but indeed it’s over my head…
As far as I’m concerned I’m fine with @Ric 's final sketch (without library!) as it is easy to use and very reliable.
What would improve with the way you suggest here?
#136
Hmm, that’s surprising.
When I USE THIS EXAMPLE ds18b20-multidrop.ino in Web IDE as is I only get this error when targeting a version 0.5.2 or before.
You may be mistaking the installed version on the device (v0.6.2) in the bottom right corner in Web IDE as the target version.
The actual target version is set in the target drawer (third icon up on the left hand bar) and I guess when you open the device info (chevron >) next to your device you’ll see you are not targeting 0.6.2.
#137
Yes, that’s what I thought it was…
Indeed, it was targeting a lower version!
I set it to v0.6.2 and Hoopla it compiles!
Thanks for pointing that out @ScruffR
All my other Particle devices have v0.6.2 targeted… How did it change back on this device?
Q: Do we need to set this target version manually for each device or will it be set sometimes by Particle?
#138
@Ric : Don’t worry and enjoy your adventure @Yosemite!
I believe the QSORT filtering you described earlier (LINK) will really perfect your sketch (without library)
It’s probably all we need to filter out all stray values. Isn’t it?
This is how the recording for one boiler (6 sensors) looks currently:
#139
This is a per device setting and will not be adapted by Particle (deliberately - but glitches might occure).
The only “exception” to this is when you chose Default (x.y.z) (currently Default (0.6.2)) as target. This instructs Web IDE to keep targeting the most recent official release.
This is intended, since some projects (for particlular devices) might rely on some “glitches” of older versions and if Particle would mess with your settings, you’d not be too happy if a fine running project suddenly threw up unexpectedly.
#140
Very useful, thanks @ScruffR!
#141
@FiDel,
This uses @ScruffR 's library that includes CRC checking. I introduced the object-oriented approach I mentioned before.
Of course, i cannot test it but you would have to check that the top, mid and bot sensors were the correct addresses.
#include <DS18B20.h>
struct Zone{
    char sensorName[4];
    uint8_t hiSensor[8];
    uint8_t loSensor[8];
    double hiTemp;
    double loTemp;
    double avgTemp;
    double energy;
void readSensorSet(Zone* zone);
double getTemp(uint8_t addr[8]);
Zone tempSensor[]{
    {"Top", {0x28,0xFF,0x0D,0x4C,0x05,0x16,0x03,0xC7}, {0x28,0xFF,0x25,0x1A,0x01,0x16,0x04,0xCD}},
    {"Mid", {0x28,0xFF,0x89,0x19,0x01,0x16,0x04,0x57}, {0x28,0xFF,0x21,0x9F,0x61,0x15,0x03,0xF9}},
    {"Bot", {0x28,0xFF,0x16,0x6B,0x00,0x16,0x03,0x08}, {0x28,0xFF,0x90,0xA2,0x00,0x16,0x04,0x76}}
Zone* Top = &tempSensor[0];
Zone* Middle = &tempSensor[1];
Zone* Bottom = &tempSensor[2];
Zone* sensorSet[] = {Top, Middle, Bottom};
double Qtot;
const int pinOneWire = D2;
const int pinLED = D7;
DS18B20 ds18b20(pinOneWire);
void setup()
  Serial.begin(9600);
  for (auto set : tempSensor)
      Particle.variable(String(set.sensorName) + "H", set.hiTemp);
      Particle.variable(String(set.sensorName) + "L", set.loTemp);  // EDIT fixed typo
  Particle.variable("ECO-Qtot", Qtot);
void loop()
  double accumulatedEnergy = 0;
  for (auto& set : tempSensor)
      set.hiTemp = getTemp(set.hiSensor);
      set.loTemp = getTemp(set.loSensor);
      set.avgTemp = (set.hiTemp + set.loTemp) / 2;
      set.energy = (set.avgTemp - set.loTemp) * 110 * 1.163 / 1000;
      accumulatedEnergy += set.energy;
  Qtot = accumulatedEnergy;
  delay(5000);
    static const int MAXRETRY = 3;
    double _temp;
    int i = 0;
    do {
         _temp = ds18b20.getTemperature(addr);
    } while (!ds18b20.crcCheck() && MAXRETRY > i++);
    if (i < MAXRETRY)
        //celsius = _temp;
        //fahrenheit = ds18b20.convertToFahrenheit(_temp);
        Serial.println(_temp);
    else
        _temp = NAN;
        //celsius = fahrenheit = NAN;
        Serial.println("Invalid reading");
    return _temp;
i’m not using:
#142
Thanks for this effort @BulldogLowell!
I will certainly come back later to this possible alternative when I have more time for experimenting AND when I’m close to the Photon used for this (I’m living one hour drive from there and cannot use serial output. That’s why I use Particle.variables instead)
First I prefer to further “polish” the sketch from @Ric, integrating another of his good ideas: QSORT “median filtering”. I believe that combination will do exactly what I need, even without CRC checks.
Also, I’d like to see the clear benefits of your proposed approach first.
For my home project it is a very essential application, as it will finally be running on 10+ Photons (and also 2 Electrons later)
When comparing the application size, it is not an advantage:
Your application (sketch + library)
  • Your sketch = 1968 bytes
  • DS18B20.cpp = 4251 bytes
  • DS18B20.h = 1129 bytes
Total = 7350 bytes => vs @Ric’s sketch Total = 2121 bytes
To be continued… :wink:
#143
I included the Particle Variables, just as you have.
adding filtering to this is somewhat trivial.
either fits fine on a Photon and neither are doing things that may affect stability in the long term.
i feel that it is:
  1. easier to read and understand what is happening… you are not moving pointers around an array which is a composite of several physical objects. this organizes the objects as they are “installed”
  2. does the CRC checking, which is basically necessary to avoid data blips (the “belt”)
  3. easier to make changes to the code, like adding the “suspenders” (software filtering)
  4. simpler code (well, if you happen to be the one writing it!)
:wink:
#144
This is a common misconception - that file size is important in defining what is “good” or not. Clarity, portability and sustainability (ability to manage or extend the code) is more important. I suspect the compiled file size is a) very similar and b) irrelevant since both will leave plenty of space for other code, if needed at all.
#145
Of course @peekay123, I can agree with what you state about “size does not matter”… :wink:
But in my 10 room sketches for the 10 Photons in my (home automation) project in progress, so many other libraries and scripts need to be ‘interwoven’ for various functions that I am constantly alerted to keep the footprint of each app as small (and simple) as possible…
Is that not a correct approach?
#146
hard to argue the contrary there.
So, I too and a bit sniped by this problem.
I thought about this a bit and figured that if I am adding CRC checks from @ScruffR 's library, then all we need to do is add the filtering.
If you are filtering, why arbitrarily de-select the highest or lowest values? If they are valid readings, then you could use a variation based on reasonable mathematics (e.g. standard deviation).
so I added a method (in this example up to 25) for temperatures to accumulate and added new readings to the value if and only if the current reading is inside a given multiple of standard deviations (I used 1.5 in this code, but you could use any number).
I thought about using qsort() but I’d have to learn how, so I decided to use C++ methods instead.
I whacked this out at lunch… maybe take it for a try while the forum gurus evaluate the code. :blush:
#include <algorithm>
#include <vector>
#define SAMPLE_SIZE 25
#define STANDARD_DEVIATION_FILTER 1.5  // we will toss any value that isnt within this number of standard deviations of the past BUFFER_SIZE readings
struct Zone{
    char sensorName[4];
    uint8_t hiSensor[8]; // high sensor
    uint8_t loSensor[8];  // low sensor
    double hiTemp;
    double loTemp;
    double avgTemp;
    double energy;
    std::vector<double> hiArray;
    std::vector<double> loArray;
    bool addHiTemp(double newVal)
        if (hiArray.size() == 0)
            hiArray.push_back(newVal);
            return true;
        double sum = std::accumulate(hiArray.begin(), hiArray.end(), 0.0);
        double mean = sum / hiArray.size();
        std::vector<double> delta(hiArray.size());
        std::transform(hiArray.begin(), hiArray.end(), delta.begin(), [mean](double x) { return x - mean; });
        double squareSum = std::inner_product(delta.begin(), delta.end(), delta.begin(), 0.0);
        double stdDeviation = std::sqrt(squareSum / hiArray.size());
        if (std::abs(newVal - mean) > STANDARD_DEVIATION_FILTER * stdDeviation)
            return false;
        hiArray.insert(hiArray.begin(), newVal);
        if(hiArray.size() >= SAMPLE_SIZE)
            hiArray.pop_back();
        return true;
    bool addLoTemp(double newVal)
        if (loArray.size() == 0)
            loArray.push_back(newVal);
            return true;
        double sum = std::accumulate(loArray.begin(), loArray.end(), 0.0);
        double mean = sum / loArray.size();
        std::vector<double> delta(loArray.size());
        std::transform(loArray.begin(), loArray.end(), delta.begin(), [mean](double x) { return x - mean; });
        double stdDeviation = std::sqrt(squareSum / loArray.size());
            return false;
        if(loArray.size() >= SAMPLE_SIZE)
            loArray.pop_back();
        return true;
Zone tempSensor[]{
double Qtot;
void setup()
  Serial.begin(9600);
void loop()
      int attempts = 0;
      double newTemp;
      do {
          newTemp = getTemp(set.hiSensor);
          attempts++;
      } while (!set.addHiTemp(newTemp) and (attempts < 5));
      set.hiTemp = set.hiArray[0];
      attempts = 0;
      do{
          newTemp = getTemp(set.loSensor);
          attempts++;
      } while (!set.addLoTemp(newTemp) and (attempts < 5));
      set.loTemp = set.loArray[0];
      set.avgTemp = (set.hiTemp + set.loTemp) / 2.0;
  delay(5000);
    double _temp;
    int i = 0;
    do {
    if (i < MAXRETRY)
        //celsius = _temp;
    else
        _temp = NAN;
    return _temp;
I was too time constrained (lazy) to reduce the two member functions to one. :wink:
#147
OK @BulldogLowell, I have now seen also your Particle.variables, but I saw also that you use serial output:
  if (i < MAXRETRY)
      // Serial.println(_temp); // For debugging only!
    else
      _temp = NAN;
      // Serial.println("Invalid reading"); // For debugging only!
I have removed those lines now and compiled/uploaded the sketch remotely.
The result was not as expected:
With @ric’s sketch I get this:
As the temperatures are not published, it seems not to work.
Also, the fact that you combined the sensors in pairs is clever in this particular application, but is something which will not always work for me:
Depending on the application, I want to be able to flexibly use any combination of 1, 2, 3, 4, 5, 6, 12, 20 … sensors and use as well the waterproof (12 bit DS18B20) type or the pcb-mount (8 bit DS18S20) type of sensors.
Remember one of my 2 important requirements:
  • Must allow MANY sensors (DS18B20 and DS18S20 versions mixed) on the same I/O pin (around 25…)
Also this mixing of types is easy with @ric 's sketch.
Due to this use of sensors in pairs, the calculation of the energy content in your sketch is wrong: You calculate the energy in only 3 of the 6 zones (you only calculate 3 averages of the H and L sensors). And this is difficult to change unless you change it completely and don’t combine sensors in pairs.
In @Ric 's sketch, the series of sensor variables is created independently and from then I am free to use them as needed.
@BulldogLowell, I just saw your endeavour during lunch time and I am grateful for your help, but I believe this is getting a bit too complicated for me…
This is the simple filtering method, ensuring the “continuity” of the data, I have in mind:
  • The current sketch updates the 6 temperatures every 5 seconds.
  • The water temperature changes so slowly that the difference between samples is very small. False readings are either much bigger or smaller.
  • Five sequential values are stored in an array, they are sorted, and then the middle value is picked and published as Particle.variable.
  • This means that the extremes will never be published.
As I mentioned earlier, you can see details here: LINK.
Let’s first see how @Ric can integrate his QSORT filtering in his current sketch.
You called this trivial, but I think it is probably a good way to achieve my goal.
The proof of the pudding will be the eating… :wink:
#148
If there is no Serial device attached, then the serial buffer will simply overflow, it won’t affect the program’s flow.
The values suggest that you haven’t validated the sensors. Did you confirm that the six addresses are indeed laid out correctly and change the pin to the proper pin for your one-wire bus? I changed the pin to D3 as in your code and posted below.
So if you exclude the bad readings, using CRC, my guess is that you are half way there. Like I said, I cannot test but thought I’d walk you along an OO path using @ScruffR 's library (CRC checking).
using other sensors is also quite easy… you know the hardware we just need to update the code to reflect those changes.
well, I guess I was demonstrating with a possible base hit, not a home run!
code with your one wire bus on D3:
#include <vector>
struct Zone{
    char sensorName[4];
    double hiTemp;
    double loTemp;
    double avgTemp;
    double energy;
        if (hiArray.size() < 10)
            return true;
            return false;
            hiArray.pop_back();
        return true;
        if (loArray.size() < 10)
            return true;
            return false;
            loArray.pop_back();
        return true;
Zone tempSensor[]{
double Qtot;
const int pinOneWire = D3;
void setup()
  Serial.begin(9600);
void loop()
      int attempts = 0;
      double newTemp;
      do {
          attempts++;
      attempts = 0;
      do{
          attempts++;
  delay(5000);
    double _temp;
    int i = 0;
    do {
    if (i < MAXRETRY)
        //celsius = _temp;
    else
        _temp = NAN;
    return _temp;
