Hi, The code is a string, parsing an (enumeration list) enum which breaks down pieces of the code. When I do that it reads the least significant digit but I need to reverse them to read the Most significant first. The only way I know how to do this is to break it down and do the weights of the pieces. Any ideas or direction would be helpful. This is an example of the code.
Code in Particle Build
char input[] = "03D88039E8987A21489A376EF603000000C0060000CF060D3B00000000009C1B";//These are the strings coming into the radio
char input1[] ="03D88039E8987A21489A376EF603000000C0060000CF060D3B00000000009C1B";
char parsedArray[14][13];
const int len[] = {2,12,2,2,4,6,6,4,4,4,6,6,2,4}; // the length of each of the pieces
int offset; // used to create offsets into the input string to the beginning of each piece
enum pieces {messageType,deviceID,deviceType,sequenceNumber,checkSum,wattHrR_L,wattHrsL_R,Voltage,Temp,Current,ampHrR_L,ampHrL_R,filler,CrC}; //to break up the sting into the different pieces there always a fixed length.
Serial.begin(115200);
delay(3000);
for(int t=0; t<2; t++){ //loop # times
for (int i=0; i<14; i++) {
snprintf(parsedArray[i], len[i] + 1, "%s", input + offset); // len[i] + 1, the plus 1 is to allow space for the terminating zero
offset += len[i];
delay(100);
// Access the individual strings using the names in the enum
Serial.println(input);
String_break();
Serial.println(input1);
// Radio_calc();
String_break();
}//end code
void String_break()
Serial.printlnf("Message Type is: ",parsedArray[HEX,messageType]);
Serial.printlnf("Device Id is: %s",parsedArray[deviceID]);
Serial.printlnf("Device Type is: %s",parsedArray[deviceType]);
Serial.printlnf("Squence #: %s",parsedArray[sequenceNumber]);
Serial.printlnf("Check Sum is: %s",parsedArray[checkSum]);
Serial.printlnf("Watt Hours R-L is: %s",parsedArray[wattHrR_L]);
Serial.printlnf("Watt Hours L-R is: %s",parsedArray[wattHrsL_R]);
Serial.printlnf("Voltage is: %s",parsedArray[Voltage]);
Serial.printlnf("Temp is: %s",parsedArray[Temp]);
Serial.printlnf("Current is: %s",parsedArray[Current]);
Serial.printlnf("Amp Hrs R_L: %s",parsedArray[ampHrR_L]);
Serial.printlnf("Amp Hrs L_R: %s",parsedArray[ampHrL_R]);
Serial.printlnf("CRC code is: %S",parsedArray[CrC]);
This is the print out of Voltage
Voltage is: C006
Need is: 06C0
Any suggestions/insight on what’s happening and how to get to the most significant value?
Appreciate any help you can provide.
