Has anyone tried to port the METRO library.
https://github.com/thomasfredericks/Metro-Arduino-Wiring
I think it is a great library for simple assignment of multiple timed events without having to keep up with interrupts etc.
Would definitely like to see that in the Spark offering.
It’s very easy, in metro.cpp, just replace this
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
with this:
#include "application.h"
Just tested this, and it works.
Thank you for explaining. Now I know how to make an attempt at some other libraries.
As far as I know, the sparkCore does follow the wiring interfacing, so if libraries are dependent on them, you can port them pretty easily. Which other libraries are you going to port?
I would like the Adafruit ADS1015 https://github.com/adafruit/Adafruit_ADS1X15
Looks like it may be similar.
I changed the lines as you said. So when I add the Metro.cpp and Metro.h to my sketch and compile, I get these errors. Am I doing something wrong?
> In file included from ../inc/spark_wiring.h:30:0,
> from ../inc/application.h:29,
> from Metro.cpp:10:
> ../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
> Metro.cpp:44:16: warning: extra tokens at end of #ifdef directive [enabled by default]
> #ifdef NOCATCH-UP
> In file included from ../inc/spark_wiring.h:37:0,
> from Metro.cpp:10:
> ../inc/spark_wiring_ipaddress.h: In member function 'IPAddress::operator uint32_t()':
> ../inc/spark_wiring_ipaddress.h:53:52: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
> operator uint32_t() { return *((uint32_t*)_address); };
> ../inc/spark_wiring_ipaddress.h: In member function 'bool IPAddress::operator==(const IPAddress&)':
> ../inc/spark_wiring_ipaddress.h:54:72: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
> bool operator==(const IPAddress& addr) { return (*((uint32_t*)_address)) == (*((uint32_t*)addr._address)); };
> ../inc/spark_wiring_ipaddress.h:54:105: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
> Metro.cpp: At global scope:
> Metro.cpp:12:1: error: 'Metro' does not name a type
> Metro::Metro()
> Metro.cpp:20:1: error: 'Metro' does not name a type
> Metro::Metro(unsigned long interval_millis)
> Metro.cpp:28:6: error: 'Metro' has not been declared
> void Metro::interval(unsigned long interval_millis)
> Metro.cpp: In function 'void interval(long unsigned int)':
> Metro.cpp:30:3: error: invalid use of 'this' in non-member function
> this->interval_millis = interval_millis;
> Metro.cpp:33:9: error: 'Metro' has not been declared
> uint8_t Metro::check()
> Metro.cpp: In function 'uint8_t check()':
> Metro.cpp:38:8: error: 'interval_millis' was not declared in this scope
> if ( interval_millis == 0 ){
> Metro.cpp:39:5: error: 'previous_millis' was not declared in this scope
> previous_millis = now;
> Metro.cpp:43:15: error: 'previous_millis' was not declared in this scope
> if ( (now - previous_millis) >= interval_millis) {
> Metro.cpp:43:35: error: 'interval_millis' was not declared in this scope
> Metro.cpp:56:6: error: 'Metro' has not been declared
> void Metro::reset()
> Metro.cpp: In function 'void reset()':
> Metro.cpp:59:3: error: invalid use of 'this' in non-member function
> this->previous_millis = millis();
> make: *** [Metro.o] Error 1
Sorry, my mistake, I commented out 1 line too many. It compiles now. Thanks
