Hello RWB, I work for quebec government so this is public stuff. I am not a professionnal C dev so my code is kind of a patchwork with multiple good libraries I found on the web, thats why I’m a bit shy sharing it
. Basic working principle is the following: boron wakes-up from sleep timer, connects to cloud, updates parameters from JSN file on FTP server, take picture, injects EXIF data including Vbat; capture time and date; RSSI, etc…,Upload picture to FTP, upload log to FTP, goes to sleep. Hardware is: Boron (obviously), uSD slot, RTC, OV2640 camera, MPPT solar charger and a pair of 18650 cells. Any details in particular you want to know? BTW, I tried multiple stuff you mentionned in other post concerning solar charging and power management, thats helped me a lot, thanks.
Now before you judge me for the use of good ol’ FTP I must say that this is sadly a design requirement.
Hello, just wanted to update this post and my observations. Since OS2.0.0 I noticed a great improvement on maximum transfer speed. I can now observe data rates up to 12 kbytes/s which suits my application just fine. Thanks to the particle team and collaborators!
Is tat with Particle publish? or some https connection?
Because if I’m not wrong the max data rate for 1s with particle publish is 4 messages of 1024bytes each so 4kB/s, and on avg 1 message per second so 1kB/s
This is as an FTP (TCP) client transfering images (binary mode) of anything from 50kB to 300kB.
