@mohit @satishgn @zachary Current master is hung in:
running make DEBUG_BUILD=y and
application.cpp has
void debug_output_(const char *p)
static boolean once = false;
if (!once)
once = true;
Serial1.begin(115200);
Serial1.print(p);
```cpp
* @file application.cpp
* @authors Satish Nair, Zachary Crockett and Mohit Bhoite
* @version V1.0.0
* @date 05-November-2013
* @brief Tinker application
Copyright (c) 2013 Spark Labs, Inc. All rights reserved.
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation, either
version 3 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this program; if not, see <http://www.gnu.org/licenses/>.
/* Includes ------------------------------------------------------------------*/
#include "application.h"
#define RENEW_INTERVAL 5*1000 // 30 secs
#define RETRY_INTERVAL 5*1000 // 10 secs
#define RESPONSE_INTERVAL 1*1000 // 1 sec
#define LET_IT_FILL_INTERVAL 3*1000 // 1 sec
TCPClient client;
char server[] = "nscdg.com";
// IO
int led = D2;
// Globals
volatile int state = 0;
volatile int wait = 0;
volatile int loopwait = 10;
volatile int tries = 0;
volatile int store = 0;
volatile int hash = 0;
volatile char command[32];
volatile int command_i=0;
uint8_t buffer[TCPCLIENT_BUF_MAX_SIZE+1]; // for EOT
int loops = 0;
int total = 0;
int wcl=2;
#define SERVER_IP 10,10,0,1
#define SERVER_PORT 9999
#define WAIT_TIME 3000
#ifdef __CS_SOURCERYGXX_REV__
#warning "Second UDP my use up memory"
UDP udpClient;
IPAddress serverAddress(SERVER_IP);
void setup2() {
pinMode(D2,OUTPUT);
system_tick_t lastMillis = (system_tick_t) -WAIT_TIME;
char buf[50];
void loop2() {
if(millis() > lastMillis + WAIT_TIME){
udpClient.begin(SERVER_PORT);
udpClient.beginPacket(serverAddress,SERVER_PORT);
snprintf(buf, sizeof(buf),"tick %ld", lastMillis);
udpClient.write(buf);
udpClient.endPacket();
lastMillis = millis();
DEBUG("tick ************ %ld",lastMillis);
digitalWrite(D2,HIGH);
delay(20);
digitalWrite(D2,LOW);
udpClient.stop();
#endif
UDP Udp2;
void setup3()
DEBUG("UDB RX");
pinMode(led, OUTPUT);
// Button resistorless
state = 0;
wait = RETRY_INTERVAL;
Udp2.begin(8738);
// Connecting
void loop3()
delay(1);
if (++loops == 100) {
loops = 0;
int packetSize = Udp2.parsePacket();
DEBUG("parsePacket %d", packetSize);
if(packetSize > 0)
int count = Udp2.read(buffer,sizeof(buffer));
buffer[count] = '\0';
DEBUG("read %d %s", count, buffer);
total += count;
int bad_mod = 0;
int bad_every = 0;
void setup1()
LOG("Test TCP BAD Every %d Usage!",bad_every);
state = 0;
// Connecting
void loop1()
delay(1);
switch(state){
case 0:
// Waiting for next time
wait-=10;
if(wait<0){
wait = 0;
state = 1;
break;
case 1:
// Connecting
bad_mod++;
DEBUG("connecting");
total = 0;
if (client.connect(server, 80)){
state = 2;
}else{
DEBUG("connection failed state 1");
state = 0;
break;
case 2:
// Requesting
if(client.connected()){
DEBUG (" Send");
client.println("GET /t.php HTTP/1.0\r\n\r\n");
if (bad_every && ((bad_mod % bad_every) == 0))
DEBUG (" Sent but not Reading it!");
wait = 1000 * 18; // longer then spark com time
state = -2;
} else {
DEBUG (" Sent Doing Read");
state = -3;
}else{
DEBUG("connection lost state 2");
state = 0;
break;
case -2:
if ((wait % 500) ==0) {
DEBUG("Waiting client.status()=%d",client.status()) ;
#if defined(GOOD)
if (!client.status()) {
state = 4;
DEBUG("Waiting Aborted - Closing") ;
#endif
wait--;
if(wait<0){
wait = 0;
state = 4;
break;
case -3:
if (client.available()) {
DEBUG ("Ready");
state = 3;
loops = 0;
wait--;
if(wait<0){
wait = 0;
state = 4;
break;
case 3: {
if(!client.connected()){
wait = 1;
state = 4;
} else {
// Receiving
int count = client.available();
if (count) {
DEBUG("client.available() %d", count);
// Print response to serial
DEBUG("client.peek %d", client.peek());
count = client.read(buffer, arraySize(buffer));
buffer[count] ='\0';
char *p = strstr((const char *)buffer,"0.1.2.3");
if (p)
total = -(p-(char*)buffer);
total += count;
DEBUG("client.read() %d", count);
debug_output_((const char*)buffer);
debug_output_("\r\n");
break;
case 4:
DEBUG("\r\n\r\n");
DEBUG("%d total Bytes Read\r\n\r\n",total);
// Disconnecting
client.stop();
DEBUG("connection closed state 4");
wait = RENEW_INTERVAL;
state = 0;
}else{
DEBUG("connection closed by server state 4");
state = 0;
break;
/* Function prototypes -------------------------------------------------------*/
int tinkerDigitalRead(String pin);
int tinkerDigitalWrite(String command);
int tinkerAnalogRead(String pin);
int tinkerAnalogWrite(String command);
/* This function is called once at start up ----------------------------------*/
//Setup the Tinker application here
//Register all the Tinker functions
setup1();
setup2();
#endif
setup3();
Spark.function("digitalread", tinkerDigitalRead);
Spark.function("digitalwrite", tinkerDigitalWrite);
Spark.function("analogread", tinkerAnalogRead);
Spark.function("analogwrite", tinkerAnalogWrite);
/* This function loops forever --------------------------------------------*/
if (!once)
once = true;
Serial1.print(p);
//This will run in a loop
loop1();
loop2();
#endif
loop3();
* Function Name : tinkerDigitalRead
* Description : Reads the digital value of a given pin
* Input : Pin
* Output : None.
* Return : Value of the pin (0 or 1) in INT type
Returns a negative number on failure
//convert ascii to integer
int pinNumber = pin.charAt(1) - '0';
//Sanity check to see if the pin numbers are within limits
if (pinNumber< 0 || pinNumber >7) return -1;
if(pin.startsWith("D"))
pinMode(pinNumber, INPUT_PULLDOWN);
return digitalRead(pinNumber);
else if (pin.startsWith("A"))
pinMode(pinNumber+10, INPUT_PULLDOWN);
return digitalRead(pinNumber+10);
return -2;
* Function Name : tinkerDigitalWrite
* Description : Sets the specified pin HIGH or LOW
* Input : Pin and value
* Output : None.
* Return : 1 on success and a negative number on failure
bool value = 0;
int pinNumber = command.charAt(1) - '0';
if(command.substring(3,7) == "HIGH") value = 1;
else if(command.substring(3,6) == "LOW") value = 0;
else return -2;
if(command.startsWith("D"))
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, value);
return 1;
else if(command.startsWith("A"))
pinMode(pinNumber+10, OUTPUT);
digitalWrite(pinNumber+10, value);
return 1;
else return -3;
* Function Name : tinkerAnalogRead
* Description : Reads the analog value of a pin
* Input : Pin
* Output : None.
* Return : Returns the analog value in INT type (0 to 4095)
pinMode(pinNumber, INPUT);
return analogRead(pinNumber);
pinMode(pinNumber+10, INPUT);
return analogRead(pinNumber+10);
return -2;
* Function Name : tinkerAnalogWrite
* Description : Writes an analog value (PWM) to the specified pin
* Input : Pin and Value (0 to 255)
* Output : None.
String value = command.substring(3);
analogWrite(pinNumber, value.toInt());
return 1;
analogWrite(pinNumber+10, value.toInt());
return 1;
else return -2;
