I have another strange bug.
I’m using the SoftAP to host a small website (html, css and javascript file) to configure my device from the web interface.
I’m using: SYSTEM_THREAD(ENABLED);
The files (html, js and css) and on an external memory.
When refresh the webpage, this function is called once per file.
char GetFileFromFlash(const char* url, const char* filename, const char * txtType, ResponseCallback* cb, void* cbArg, Writer* result)
if (strcmp(url, String::format("/%s", filename).c_str()) == 0) {
Serial.printlnf("Reading %s from flash", filename);
cb(cbArg, 0, 200, txtType, nullptr);
// Dump file from memory...
stopSPI = 1;
destinationFile = myFileOpen(filename);
if (destinationFile < 0)
// Try again
ExitMyPage(cb, cbArg, result, "Open error", true);
stopSPI = 0;
return 1;
// File length
int size = myFileGetSize(destinationFile);
while (size > 0)
int toRead = (size > sizeof(contentData)) ? sizeof(contentData) : size;
int read = 0;
read = myFileRead(destinationFile, contentData, toRead);
if (read == toRead)
result->write(contentData, read);
uint32_t mil = millis();
while ((millis() - mil) < 50)
Particle.process();
size -= read;
else
Serial.printlnf("%s read error: %d", filename, read);
result->write("Read Error");
size = 0; // on quitte
myFileClose(destinationFile);
stopSPI = 0;
Serial.printlnf("%s read ended", filename);
return 1;
stopSPI = 0;
return 0;
I have a Serial.println(“Loop”); in my loop code to monitor when my loop is called.
I noticed that if the Process is too short (like 10ms instead of 50ms), the loop is stop being called and never called anymore. But the softap continue to work and I can refresh webpages again and again but my usercode is not executed anymore until next reset.
Particle.process();
My files are bigger are between 2k and 20k. Maybe there is a buffer overflow somewhere related to the write function?
