I am looking for a CAD model of the M1 Enclosure and 9300 mAh battery. Trying to determine if I can fit a raspberry pi with CAN hat in the enclosure.
There's a STEP file of the enclosure in the datasheet, but not all of those parts. The 9300 mAh split battery fits under the base panel, so it shouldn't affect the HAT, so the primary issue should be whether the CAN HAT will fit under the top cover.
Thanks for the quick and helpful reply. The datasheet STEP file only has the back cover. That’s why I am looking for a model with the front cover as well.
