When I try to log into the Particle Cloud in Desktop IDE I get the error, “mfa_required”. I logged out to try to solve the issue where no devices load and when I went to log back in I got this error. Any guidance would be appreciated. Thanks
I disabled MFA and was able to log in. What is the process to log in via Desktop IDE when MFA is turned on?
The current desktop IDE does not support MFA and there are no plans to as we are moving to the recently announced Particle Workbench as our mainline desktop solution.
The objective is to log in from Desktop IDE , witch is filling with error saying MFA is required. So are you saying desktop IDE is not supported anymore ?
Currently there still are two desktop IDEs: Particle Dev and Particle Workbench. As mentioned above, support for Particle Dev will be phased out in favor of Workbench. As such, MFA won’t become available for Dev anymore.
I'd say the answer if you asked support crew would be: "You can't and won't be. T/MFA is a new feature that came after development for Desktop IDE was stopped. You either need to move to Workbench or deactivate T/MFA".
So is developer workbench released yet ? I didn’t see it mentioned in the documentation as a dev option . I found an announcement of its future release.
You can also log into https://console.particle.io and use the Edit Account item in the popup menu with your email address in the upper right corner of the console.
