Any help would be much appreciated. I was able to get this working on the old interface (see Matt’s instructions). My guess would be the user/libraries folder, but I see that the “libraries” in there only have a .h file and look a lot different than how typical libraries are laid out. Any help would be appreciated, thanks!
its in the user/applications folder. just create a new folder for your app and libraries, then compile that folder using APP=newfoldername
make sure your app has a cpp extension…
and just drop the .cpp and .h files in the same folder
Thanks, that fixes it once I remove all the examples and test folders from the libraries. It seems to auto-compile those too. That’s pretty sweet that I don’t have to change .mk files anymore.
In the long term, I think I will still split the library files out to separate directories just to keep myself sane
Yep that can be done easily too… pretty sure you can just add the extra foldername to the include just like you would with the webIDE libraries
#include "folder/library.h"
