LocalTimeRK changing times
Does anyone know if when using fromJson it will wipe out what was scheduled?
I have one board that seems to be remembering and old time that was put in. Should I be clearing something before setting the new time?
I am only sending one tm xx:xx:xx in the json.
A bit of your code would be helpful, as there are many ways the library can be used.
Yes sorry.
Inside loop
if (publishSchedule.isScheduledTime()){
  //TODO remove  put loop stuff
  LockDoor();
LockDoor just changes a relay
Here is when I set a time
int LockTime(String command) {
    publishSchedule.fromJson(command);
    return 55;
Here is an example of the string going in.
[{\"tm\":\"10:55:02\"}]
So anytime I want to change that time it looks like it adds to it and not a replace.
Yes, the schedule is additive. Just call:
publishSchedule.clear();
to clear the existing schedule to replace it.
Works perfectly.
Thanks.
