Listening for response from DL failed
I put it in listening mode, give it my credentials. Then, it starts blinking green, and then it begins breathing green. Through ‘screen’, I can se the following output:
listening for response from DL failed
max num retries reached, deleting command
over and over again. When I search for these statements here, or google, I get nothing. No idea what is going on.
Not sure where you are getting those messages.
  • Which device are you on? Photon or Core?
  • Have you managed to claim it already?
  • What is the RGB led status?
BTW, we are :spark: Particle (formerly Spark) if you happen to use any software of a similar name…
