# Lipo Charge with Solar Panel and Deep Sleep
**URL:** <https://community.particle.io/t/lipo-charge-with-solar-panel-and-deep-sleep/25635>\
**Category:** Hardware\
**Created:** [September 6, 2016, 11:57am UTC](https://community.particle.io/t/lipo-charge-with-solar-panel-and-deep-sleep/25635 "2016-09-06T11:57:40Z")\
**Showing post:** 7
**Post date:** [February 16, 2017, 1:52am UTC](https://community.particle.io/t/lipo-charge-with-solar-panel-and-deep-sleep/25635/7 "2017-02-16T01:52:34Z")
> [@ScruffR](#):
> Unless you explicitly switch off the charging, the LiPo will get charged during sleep, but I think only with 100mA (by default)
The info @jprivacoba is looking for is in this post:
> [@Bug Bounty: Electron not booting after battery discharges completely](https://community.particle.io/t/bug-bounty-electron-not-booting-after-battery-discharges-completely/25043/69):
> If you apply power to the Vin terminals while the Electron is in sleep modes you will get the 100ma charge limit. If you use my PMIC code to bump charging current to 1amp then once the setup loop runs the charging can go up to 1 amp. Now this higher charging current will hold as long as the power applied to Vin remains regardless of charging current, so you will still be able to charge at the higher currents even in deep sleep. This should be no problem during the dayligh…
_[View the full topic](https://community.particle.io/t/lipo-charge-with-solar-panel-and-deep-sleep/25635)._
