Lin Bus assistance
I would like to create a Lin bus master to interface with a slave.
According to “LIN Bus support, USART hardware flow control configuration support #930
I should be able to use
Serial1.begin(9600, LIN_MASTER_13B);
However, each time I get an error that “LIN_MASTER_13B” has not been defined. Where am I going wrong?
Also, if anyone has some example code that would be greatly appreciated
Cheers
Michael
That feature is targeted for 0.6.0, which is currently in development. You’ll need to wait for release or build your own system firmware develop branch in order to use that feature.
Makes sense now - thanks
