Hello,
I have an existing codes in C++ using simple AT commands to read GPS data and send them to a HTTP server. This codes work on FONA 808. Here I have found a Library to get GSP data (AssetTracker.cpp). Does anyone know of a library that can be used to sent data to a HTTP server. Such a library will give me the option to set and configure Access Point and then send the data. We have implemented AT commands and to send data we use for example
SendAtCommand(“AT+CGDCONT=1”,"“IP”","“data.lycamobile.de”").
If there is an existing library I will like to use it. If not I can use the AdaFruit SendCommand() and later create a library out of it. Such will also be used to send and receive sms.
