Ever since I update my core to use the Spark Dallas Temperature library from the libraries tab, rather than a copy I had in my app directly, I keep getting back a temperature of -196.6 on almost all reads, which is the DEVICE_DISCONNECTED_F error. Unfortunately I had no way to go back to my previous version since there’s still no versioning in the Web IDE. Running curl in a loop with a 5 second sleep out of 3343 attempts only 264 of them came back with a real result.
I added some debugging but I don’t see why it’s happening.
Anyone know why I might get this error?
This is my update function:
static void update()
if (!sensors.validAddress(address)) {
sensors.getAddress(address, 0);
sprintf(addrString, "%02x%02x%02x%02x%02x%02x%02x%02x - %s,%s",
address[0],
address[1],
address[2],
address[3],
address[4],
address[5],
address[6],
address[7],
sensors.validAddress(address) ? "VAL" : "INV",
sensors.isConnected(address) ? "CON" : "DISC"
if (sensors.validAddress(address)) {
sensors.requestTemperatures();
// uint8_t scratchPad[9];
// float temp = sensors.rawToFahrenheit(sensors.calculateTemperature(address, scratchPad));
float temp = sensors.getTempF(address);
temperature = (int) (temp + 0.5f);
sprintf(tempString, "%f", temp);
else {
temperature = -123;
strcpy(tempString, "Invalid Address, Sigh");
Spark.publish("temperature", tempString, EVENT_EVERY_MS / 1000, PRIVATE);
Same happens if I just watch the event stream:
event: temperature
data: {"data":"-196.600006","ttl":"30","published_at":"2015-01-19T03:46:43.042Z","coreid":"foo"}
event: temperature
data: {"data":"-196.600006","ttl":"30","published_at":"2015-01-19T03:47:13.041Z","coreid":"foo"}
