My Electron device keeps blinking red (not exactly red, a little red, a little green and a little yellow).
My SIM number is 89340 76500 00283 395 2.
The device id is 34001c001451343334363036.
The firmware version is 0.5.1.
Thanks.
Thanks.
Considering that’s a bit of a vague description, to say the least, would you mind making a video so we can see without a doubt what colors/patterns are being displayed?
The video is here:
https://www.dropbox.com/s/0hbddc9vn5l03x1/3.mp4?dl=0
If I’m not mistaken, that’s yellow, not red.
Blinking yellow would indicate DFU mode, as described in the docs here: https://docs.particle.io/guide/getting-started/modes/electron/#dfu-mode-device-firmware-upgrade-
What happens if you reset it?
There’s also a lot going on on that breadboard!
You might want to take the Electron out of that (excuse) rats nest and try without external circuitry
If you make a video of the RGB LED try to show it from directly above and with reduced exposure to make it easier to judge the colors.
The same after I reset it many times.
But I can’t understand. If it is paused after it reach 1m limit, why did it reach 6.57MB?
Your SIM does not currently have a data limit. It will only have a data limit after you click the blue button.
The new video is here:
https://www.dropbox.com/s/iih9bufcq69znnq/1.mp4?dl=0
Is there any way to do a factory reset? I don’t know if the device is damaged or not. I can flash the code correctly.
The neares thing to a factory reset is via DFU Mode
particle update
particle flash --usb tinker
Very strange. Luckily it works now.
