I’ve started building several apps using Ionic Framework and just dug into the Javascript SDK for a slightly easier library. Sadly, it looks like //cdn.jsdelivr.net/sparkjs/0.2.4/spark.min.js
is injecting some inline CSS that breaks the .modal
styles in Ionic.
Any way to rename, prevent or disable this behavior without modifying the spark.min.js
? I would rather pull from a CDN instead of a local file…
Linking issue: https://github.com/spark/sparkjs/issues/45
