Hi all,
I am busy with a controller for my Philips Hue lights. I would like to place the Photon behind my wall switch to adjust brightness, switch off with timedelay and switch to default state. It is all working now, but some strange behaviour on the interrupt.
What I do is when i want to increase brightness, first check if the light is on, if not, swtich it on first.
When I attach the interupt to pin D1 with rising edge to a function where the getHue function is called. The Photon does not react anymore. The software seems to hang…
If I set a flag in the interrupt function, and in my main check if the flag is set, if so, call the function getHue(), and in this function, clear the flag. The getHue is called manytimes. I expect the function is called only during rising edge.
Below my code as it is right now, getHue is also called when no rising edge is detected.
TCPClient client;
const char hueHubIP[] = "192.168.1.100"; // Hue hub IP
const char hueUsername[] = "newdeveloper"; // Hue username
const int hueHubPort = 80;
/*PROTOTYPES*/
void checkStatus(void);
bool statusFlag = false;
// Hue variables
bool hueOn = false; // on/off
int hueBri; // brightness value
long hueHue; // hue value
unsigned long buffer=0; //buffer for received data storage
unsigned long addr;
int incPin = D1;
int decPin = D0;
int bt1Pin = D2;
int bt2Pin = D3;
unsigned int incState;
unsigned int decState;
unsigned int bt1State;
unsigned int bt2State;
/* Structure to store the status of the hue lights*/
struct hue_t {
bool On;
int Bri;
int Sat;
int Hue;
} hue;
void setup(){
pinMode(incPin, INPUT_PULLDOWN);
attachInterrupt(D1, getHueStatus, RISING);
pinMode(decPin, INPUT_PULLDOWN);
pinMode(bt1Pin, INPUT_PULLDOWN);
pinMode(bt2Pin, INPUT_PULLDOWN);
delay(100);
Serial.print("Setup Done");
void getHueStatus(void){
statusFlag = true;
void loop(){
incState = digitalRead(incPin);
decState = digitalRead(decPin);
bt1State = digitalRead(bt1Pin);
bt2State = digitalRead(bt2Pin);
/*If the flag is set on rising edge, get Hue status*/
if (statusFlag == true){
getHue(1);
if ((incState == HIGH) && hueOn){
delay(300); //Add delay
Serial.println("Increase with 25");
String jsonData = "{\"bri_inc\": 25}";
sendJSON(jsonData);
else if ((incState == HIGH) && !hueOn){
//getHue(1);
Serial.println("Light was off, switch it on!");
String jsonData = "{\"on\": true}";
sendJSON(jsonData);
else if (decState == HIGH){
delay(300);
Serial.println("Assume the lights are on, decrease brightness!");
String jsonData = "{\"bri_inc\": -25}";
sendJSON(jsonData);
else if (bt1State == HIGH){
/*Switch ON the lights*/
Serial.println("set to default scene");
//String jsonData = "{\"scene\": Relax}";
String jsonData = "{\"bri\": 229, \"sat\": 213, \"hue\": 13088}";
sendJSON(jsonData);
else if (bt2State == HIGH){
/*Call script that turn the lights off in 2 minutes*/
getHue(1);
if (hueOn == true){
Serial.println("switch off with transition time of 2 minutes");
String jsonData = "{\"on\": false, \"transitiontime\": 1200 }";
sendJSON(jsonData);
delay(500);
* @brief; this function is called to get the light status
* if we want to inc or dec the brightness, first we have to get the current brightness
boolean getHue(int lightNum){
if (client.connect(hueHubIP, hueHubPort)){
Serial.println("getHue Function");
client.print("GET /api/");
client.print(hueUsername);
client.print("/lights/");
client.print(lightNum);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(hueHubIP);
client.println("Content-type: application/json");
client.println("keep-alive");
client.println();
while (client.connected()){
if (client.available()){
client.findUntil("\"on\":", "\0");
hueOn = (client.readStringUntil(',') == "true"); // if light is on, set variable to true
client.findUntil("\"bri\":", "\0");
hueBri = client.readStringUntil(',').toInt(); // set variable to brightness value
client.findUntil("\"hue\":", "\0");
hueHue = client.readStringUntil(',').toInt(); // set variable to hue value
Serial.println(hueOn);
Serial.println(hueBri);
Serial.println(hueHue);
break; // not capturing other light attributes yet
statusFlag == false;
client.stop();
return true; // captured on,bri,hue
else
return false; // error reading on,bri,hue
/* setHue() is our main command function, which needs to be passed a light number and a
* properly formatted command string in JSON format (basically a Javascript style array of variables
* and values. It then makes a simple HTTP PUT request to the Bridge at the IP specified at thestart.
void sendJSON(String jsonData) {
if (client.connect(hueHubIP, hueHubPort)) {
if(client.connected()) {
Serial.println("Connected");
unsigned int jsonLen = jsonData.length(); //get length of JSON data
client.println("PUT /api/newdeveloper/groups/1/action");
//client.println("PUT /api/newdeveloper/lights/1/state");
// client.print(hueUsername);
client.println("Connection: keep-alive"); //
client.println("Host: "); // 192.168.1.100"); //same as server
client.println("Content-Type: text/plain;charset=UTF-8"); //
client.print("Content-Length: "); //param
client.println(jsonLen); //brightness string + val length;
client.println(); // blank line before body
client.print(jsonData);
delay(100); // slight delay IMPORTANT
client.stop();
