Is retained memory still working on P2
Hi, I’m considering to migrate a product from P1 to P2. Since the existing program takes the advantage of retained memory, I’d like to check if it still works on P2 and what the size is. If sadly not, any suggestion in this regard will be highly appreciated.
Thanks.
I ran this search:
Then found this hit.
Cheers
No surprise :rofl: Thank you @gusgonnet
