Is it possible to improve error reporting in IDE?
When using the locally installed IDE, and doing deployment via the cloud, if you don’t constantly stare at the footer of the editor you might miss the fact that the deployment failed.
Example:
47
52
04
Which IDE are we talking about here? Particle Dev or the new Particle Workbench?
The Particle Dev local IDE will likely not get any future updates. The Particle Workbench (VS Code) will be the preferred desktop IDE environment and all new features will be implemented there.
