Invalid DFU suffix signature
Error during download get_status
This is the error code I receive when i try to run the "particle doctor" and put the device in DFU Mode.
I can do "particle setup" and everything seems well to me, but the device blinks a strange led: half blu and half red...
I do searched and tryed all the solutions found in this forum but it’s still not working.
Also, in build.particle.io I can’t see the firmware on the Photon. It’s not indicated.
But in console.particle.io Diagnostic Test tells everything is fine with my Photon…
The standard response to anything to do with "Invalid DFU suffix signature" is: "This is only a warning and can be ignored entirely"
The docs do show this image
This is where you see what Device OS is currently installed on the device and the dropdown list lets you select what version the firmware you may build will be targeting.
If you want to know what the currently installed application firmware is, you can use particle serial inspect to find out, but it's usually not important when you can just flash a properly targeted version to your device (which should be possible while breathing magenta).
Or you just run this with most recent CLI (currently 1.31.0) installed
Nope.
That image is what I would like to see. But I see this one instead:
I can successfully signal my Photon but I can’t flash anything on it. I already said I tryed all the solutions indicated, and all of them have been unsuccessfull.
If I try to run those CLI commands I just received the Error message I’m compaling with in this post.
Is there a way to break this loop?
I don’t know what happened with my Photon. Done nothing hasty. I have too other Photon that have been mistreat, comparing to this one, and they all work perfectly
Thank you so much!
Your advice let me escape that loop! Now, serial inspect is fine in each part.
I have some trouble with Wifi module that seems to be off…
You’ll hear me soon if I can’t solve by myself! O:)
I still have some trouble but cannot say why..
My Photon, now, breath green.
Particle Doctor fail in Wifi hotspot step:
Reset Wi-Fi hotspot name in listening mode
? Select Continue when ready Continue
The Doctor didn't complete sucesfully. undefined
I've already unclaimed this Photon (I don't see it anymore in cloud nor in build IDE) and changed Keys.
I tryed to claim this Photon again using Particle App but it stops at the last step: Verifying product ownership. In build IDE it says I can't claim that device.
What happens when you put the device in Safe Mode?
Unclaiming/reclaiming a device does virtually never help solving connection issues, so don’t even try
Due to lack of insight on what application your device is currently running my guess would be that your code is starving the cloud process from processing time and hence the connection drops.
Breathing green indicates WiFi.ready() but !Particle.connected() - usually because the application does “demand” it that way.
Ok, in safe mode I could claim my device by app. Even from cloud i can see it running good (Diagnostic says everything looks good).
Now, what’s the clever step? Can I flash something in safe mode, to erase the application that is maybe the root of my connection problems?
I don’t have any idea of what application it is… too times passed by!
Then you either need to cd into the Downloads folder or provide the entire path to CLI - how would CLI know where you placed the file without being told?
