I am working on developing a comms stack that is shared between an Electron project in Particle Workbench and a bootloader that is being written in a different IDE (STM32CubeIDE).
I have a header file located in the non-particle project that I would like to include in my Particle project.
Is there any way to add a symbolik link in Visual Studio Code such that I can include that file (accessed via symblink that is located in the my Particle Workbench project’s src
folder)?
Alternatively, is there a way to change the include paths used by the Particle Workbench build process (make file)?
I think I can go the other way around if I really have to (just copy the file I need to the Particle folder and then configure include path in STM32CubeIDE to include the Particle folder in question.) but I wanted to check if I can do it from within Particle Workbench first.
UPDATE
Using mkLink
command line utility on a Windows machine lets you make symbolic links. You can also use a GUI for it: Symlinker (GitHub)
