@brianr Yes I did and here is the code:
.ino code:
// SDL_Arduino_INA3221 Library Test Code
// SDL_Arduino_INA3221.cpp Arduino code - runs in continuous mode
// Version 1.1
// SwitchDoc Labs January 31, 2015
// This was designed for SunAirPlus - Solar Power Controller - www.switchdoc.com
#include "Particle.h"
#include "SDL_Arduino_INA3221.h"
SDL_Arduino_INA3221 ina3221;
// the three channels of the INA3221 named for SunAirPlus Solar Power Controller channels (www.switchdoc.com)
#define LIPO_BATTERY_CHANNEL 1
#define SOLAR_CELL_CHANNEL 2
#define OUTPUT_CHANNEL 3
void setup(void)
Serial.begin(57600);
Serial.println("SDA_Arduino_INA3221_Test");
Serial.println("Measuring voltage and current with ina3221 ...");
ina3221.begin();
void loop(void)
Serial.println("------------------------------");
float shuntvoltage1 = 0;
float busvoltage1 = 0;
float current_mA1 = 0;
float loadvoltage1 = 0;
busvoltage1 = ina3221.getBusVoltage_V(LIPO_BATTERY_CHANNEL);
shuntvoltage1 = ina3221.getShuntVoltage_mV(LIPO_BATTERY_CHANNEL);
current_mA1 = -ina3221.getCurrent_mA(LIPO_BATTERY_CHANNEL); // minus is to get the "sense" right. - means the battery is charging, + that it is discharging
loadvoltage1 = busvoltage1 + (shuntvoltage1 / 1000);
Serial.print("LIPO_Battery Bus Voltage: "); Serial.print(busvoltage1); Serial.println(" V");
Serial.print("LIPO_Battery Shunt Voltage: "); Serial.print(shuntvoltage1); Serial.println(" mV");
Serial.print("LIPO_Battery Load Voltage: "); Serial.print(loadvoltage1); Serial.println(" V");
Serial.print("LIPO_Battery Current 1: "); Serial.print(current_mA1); Serial.println(" mA");
Serial.println("");
float shuntvoltage2 = 0;
float busvoltage2 = 0;
float current_mA2 = 0;
float loadvoltage2 = 0;
busvoltage2 = ina3221.getBusVoltage_V(SOLAR_CELL_CHANNEL);
shuntvoltage2 = ina3221.getShuntVoltage_mV(SOLAR_CELL_CHANNEL);
current_mA2 = -ina3221.getCurrent_mA(SOLAR_CELL_CHANNEL);
loadvoltage2 = busvoltage2 + (shuntvoltage2 / 1000);
Serial.print("Solar Cell Bus Voltage 2: "); Serial.print(busvoltage2); Serial.println(" V");
Serial.print("Solar Cell Shunt Voltage 2: "); Serial.print(shuntvoltage2); Serial.println(" mV");
Serial.print("Solar Cell Load Voltage 2: "); Serial.print(loadvoltage2); Serial.println(" V");
Serial.print("Solar Cell Current 2: "); Serial.print(current_mA2); Serial.println(" mA");
Serial.println("");
float shuntvoltage3 = 0;
float busvoltage3 = 0;
float current_mA3 = 0;
float loadvoltage3 = 0;
busvoltage3 = ina3221.getBusVoltage_V(OUTPUT_CHANNEL);
shuntvoltage3 = ina3221.getShuntVoltage_mV(OUTPUT_CHANNEL);
current_mA3 = ina3221.getCurrent_mA(OUTPUT_CHANNEL);
loadvoltage3 = busvoltage3 + (shuntvoltage3 / 1000);
Serial.print("Output Bus Voltage 3: "); Serial.print(busvoltage3); Serial.println(" V");
Serial.print("Output Shunt Voltage 3: "); Serial.print(shuntvoltage3); Serial.println(" mV");
Serial.print("Output Load Voltage 3: "); Serial.print(loadvoltage3); Serial.println(" V");
Serial.print("Output Current 3: "); Serial.print(current_mA3); Serial.println(" mA");
Serial.println("");
delay(1000);
Here is the .CPP file:
// Version 1.1
Initial code from INA219 code (Basically just a core structure left)
@author K.Townsend (Adafruit Industries)
@license BSD (see BSDlicense.txt)
@brief Sends a single command byte over I2C
void SDL_Arduino_INA3221::wireWriteRegister (uint8_t reg, uint16_t value)
Wire.beginTransmission(INA3221_i2caddr);
Wire.write(reg); // Register
Wire.write((value >> 8) & 0xFF); // Upper 8-bits
Wire.write(value & 0xFF); // Lower 8-bits
Wire.endTransmission();
@brief Reads a 16 bit values over I2C
void SDL_Arduino_INA3221::wireReadRegister(uint8_t reg, uint16_t *value)
delay(1); // Max 12-bit conversion time is 586us per sample
Wire.requestFrom(INA3221_i2caddr, (uint8_t)2);
*value = ((Wire.read() << 8) | Wire.read());
void SDL_Arduino_INA3221::INA3221SetConfig(void)
// Set Config register to take into account the settings above
uint16_t config = INA3221_CONFIG_ENABLE_CHAN1 |
INA3221_CONFIG_ENABLE_CHAN2 |
INA3221_CONFIG_ENABLE_CHAN3 |
INA3221_CONFIG_AVG1 |
INA3221_CONFIG_VBUS_CT2 |
INA3221_CONFIG_VSH_CT2 |
INA3221_CONFIG_MODE_2 |
INA3221_CONFIG_MODE_1 |
INA3221_CONFIG_MODE_0;
wireWriteRegister(INA3221_REG_CONFIG, config);
@brief Instantiates a new SDL_Arduino_INA3221 class
SDL_Arduino_INA3221::SDL_Arduino_INA3221(uint8_t addr, float shuntresistor) {
INA3221_i2caddr = addr;
INA3221_shuntresistor = shuntresistor;
@brief Setups the HW (defaults to 32V and 2A for calibration values)
void SDL_Arduino_INA3221::begin() {
Wire.begin();
// Set chip to known config values to start
INA3221SetConfig();
Serial.print("shut resistor="); Serial.println(INA3221_shuntresistor);
Serial.print("address="); Serial.println(INA3221_i2caddr);
@brief Gets the raw bus voltage (16-bit signed integer, so +-32767)
int16_t SDL_Arduino_INA3221::getBusVoltage_raw(int channel) {
uint16_t value;
wireReadRegister(INA3221_REG_BUSVOLTAGE_1+(channel -1) *2, &value);
// Serial.print("BusVoltage_raw=");
// Serial.println(value,HEX);
// Shift to the right 3 to drop CNVR and OVF and multiply by LSB
return (int16_t)(value );
@brief Gets the raw shunt voltage (16-bit signed integer, so +-32767)
int16_t SDL_Arduino_INA3221::getShuntVoltage_raw(int channel) {
uint16_t value;
wireReadRegister(INA3221_REG_SHUNTVOLTAGE_1+(channel -1) *2, &value);
// Serial.print("ShuntVoltage_raw=");
return (int16_t)value;
@brief Gets the shunt voltage in mV (so +-168.3mV)
float SDL_Arduino_INA3221::getShuntVoltage_mV(int channel) {
int16_t value;
value = getShuntVoltage_raw(channel);
return value * 0.005;
@brief Gets the shunt voltage in volts
float SDL_Arduino_INA3221::getBusVoltage_V(int channel) {
int16_t value = getBusVoltage_raw(channel);
return value * 0.001;
@brief Gets the current value in mA, taking into account the
config settings and current LSB
float SDL_Arduino_INA3221::getCurrent_mA(int channel) {
float valueDec = getShuntVoltage_mV(channel)/INA3221_shuntresistor;
return valueDec;
Here is the .H file:
// Version 1.1
@author K. Townsend (Adafruit Industries)
I2C ADDRESS/BITS
#define INA3221_ADDRESS (0x40) // 1000000 (A0+A1=GND)
#define INA3221_READ (0x01)
CONFIG REGISTER (R/W)
#define INA3221_REG_CONFIG (0x00)
#define INA3221_CONFIG_RESET (0x8000) // Reset Bit
#define INA3221_CONFIG_ENABLE_CHAN1 (0x4000) // Enable Channel 1
#define INA3221_CONFIG_ENABLE_CHAN2 (0x2000) // Enable Channel 2
#define INA3221_CONFIG_ENABLE_CHAN3 (0x1000) // Enable Channel 3
#define INA3221_CONFIG_AVG2 (0x0800) // AVG Samples Bit 2 - See table 3 spec
#define INA3221_CONFIG_AVG1 (0x0400) // AVG Samples Bit 1 - See table 3 spec
#define INA3221_CONFIG_AVG0 (0x0200) // AVG Samples Bit 0 - See table 3 spec
#define INA3221_CONFIG_VBUS_CT2 (0x0100) // VBUS bit 2 Conversion time - See table 4 spec
#define INA3221_CONFIG_VBUS_CT1 (0x0080) // VBUS bit 1 Conversion time - See table 4 spec
#define INA3221_CONFIG_VBUS_CT0 (0x0040) // VBUS bit 0 Conversion time - See table 4 spec
#define INA3221_CONFIG_VSH_CT2 (0x0020) // Vshunt bit 2 Conversion time - See table 5 spec
#define INA3221_CONFIG_VSH_CT1 (0x0010) // Vshunt bit 1 Conversion time - See table 5 spec
#define INA3221_CONFIG_VSH_CT0 (0x0008) // Vshunt bit 0 Conversion time - See table 5 spec
#define INA3221_CONFIG_MODE_2 (0x0004) // Operating Mode bit 2 - See table 6 spec
#define INA3221_CONFIG_MODE_1 (0x0002) // Operating Mode bit 1 - See table 6 spec
#define INA3221_CONFIG_MODE_0 (0x0001) // Operating Mode bit 0 - See table 6 spec
SHUNT VOLTAGE REGISTER (R)
#define INA3221_REG_SHUNTVOLTAGE_1 (0x01)
BUS VOLTAGE REGISTER (R)
#define INA3221_REG_BUSVOLTAGE_1 (0x02)
#define SHUNT_RESISTOR_VALUE (0.1) // default shunt resistor value of 0.1 Ohm
class SDL_Arduino_INA3221{
public:
SDL_Arduino_INA3221(uint8_t addr = INA3221_ADDRESS, float shuntresistor = SHUNT_RESISTOR_VALUE);
void begin(void);
float getBusVoltage_V(int channel);
float getShuntVoltage_mV(int channel);
float getCurrent_mA(int channel);
private:
uint8_t INA3221_i2caddr;
float INA3221_shuntresistor;
void wireWriteRegister(uint8_t reg, uint16_t value);
void wireReadRegister(uint8_t reg, uint16_t *value);
void INA3221SetConfig(void);
int16_t getBusVoltage_raw(int channel);
int16_t getShuntVoltage_raw(int channel);
