@Ric, I could be wrong but here is why I thought it was on by default. Taken from the htu21d libary : // 0x2 is the default value of the user register
In the meanwhile, I am trying to modify the library to add a function to print out the setting of the htu21d and manually turn on and off the heater to see if it make a difference.
bool HTU21D::begin(void)
// Only join the I2C bus as master if needed
if(! Wire.isEnabled())
Wire.begin();
// Reset the sensor
reset();
// Read User register after reset to confirm sensor is OK
return(read_user_register() == 0x2); // 0x2 is the default value of the user register
