HttpClient - Multiple instances possible?
Does anyone know if a second instance of HttpClient is supported if the first instance is being used as the client for HTTPServer? i.e. -
First instance is:-
HTTPServer server;
HTTPClient clientOne;
clientOne = server.available(); // Used by the server instance
Second instance:-
HTTPClient clientTwo; // Another instance for retrieving data from a different web server
clientTwo.Connect(ipaddress,port)
cleintTwo.println(“GET /somewebpage.html HTTP/1.1”);
I’ve left out all the supporting code for clarity.Thanks in advance,
Tb.
Do you mean the TCPServer and TCPClient classes?
You can have multiple instances of the client class. There’s probably some limit to the number of concurrent TCP sessions / socket resources though I don’t know what they are.
