Httpclient library status documention
Where can I find documentation for the httpclient library? More specifically, I need to know the meaning of the status values. I know that 200 means success, but what does -1 mean, for example?
Thanks.
the 200 is a standard http response code, you can google those. as for the -1 means the connection failed or there was no response
if you look at the httpclient.cpp is pretty well commented
