Hi, I am playing around with a DFRobot PN532 Gravity module (link to library that I ported: Particle Web IDE).
I have it mostly working, but if I sometimes move the NFC tag too quickly / do so repeatedly, the Photon goes into red LED / hard fault and restarts. One thing I did observe is when this occurs, the card UID length that it picks up is quite long (200+) when it is actually 7 on a full read - so perhaps some kind of heap overflow?
I have also seen the “this card type is not NTAG21x…” message sometimes show up before the crash as well when moving the tag too quickly, even though it is an NTAG NFC tag.
The example code I am using to try and read the card UID is below. Is there a way to see why the SOS happens? Thanks!
#include <dfrobot-pn532.h>
#define BLOCK_SIZE 16
#define block (5)
//Initialize MEGA2560
DFRobot_PN532_UART nfc;
DFRobot_PN532:: sCard_t NFCcard;
Serial.begin(115200);
while (!nfc.begin(&Serial1)) {
Serial.println("initial failure");
delay (1000);
Serial.println("Waiting for a card......");
if (nfc.scan()) {
Serial.println("card detected");
The NTAG's EEPROM memory is organized in pages with 4 bytes per page. NTAG213 variant has
45 pages, NTAG215 variant has 135 pages and NTAG216 variant has 231 pages in total.
The memory organization can be seen in the following table .
page Adr BYTE number within a page
0 | 1 | 2 | 3 |
0 serial number
1 serial number
2 serial number|internal | lock bytes| lock bytes|
3 Capability Container(cc)
-----------------------NTAG213----------------------------------
4
... user memory
39
------------------------NTAG215---------------------------------
4
... user memory
129
------------------------NTAG216---------------------------------
4
... user memory
225
*/ NFCcard = nfc.getInformation();
if (NFCcard.AQTA[1] == 0x44 && memcmp(NFCcard.cardType, "Ultralight", 10) != 0) {
Serial.print("UID Lenght: "); Serial.println(NFCcard.uidlenght);
Serial.print("UID: ");
if (NFCcard.uidlenght <= 10) {
for (int i = 0; i < NFCcard.uidlenght; i++) {
Serial.print(NFCcard.uid[i], HEX);
Serial.print(" ");
else {
Serial.println("The card type is not NTAG21x...");
else {
Serial.println("no card");
delay(2000);
