How to start / stop application to trigger logic analyzer
Hello…
I have an application on an Argon that is embedded onto another PCB and I am trying to troubleshoot. I have the logic analyzer connected to the design and am trying to track down some serial communication issues (SPI, one-wire, etc.) After flashing the target it automatically begins to run. I would like to know if there is a way to halt and re-start the target at will using WorkBench without a debugger connected?
Secondly how would you recommend restarting the application without compiling and reflashing each time (should I just use the reset button)?
The reset button is a good option. You can also use the RST (reset) pin or in your code you can use any logic to call System.reset().
