# How to pass unescaped JSON to Azure IoTHub?
**URL:** <https://community.particle.io/t/how-to-pass-unescaped-json-to-azure-iothub/28142>\
**Category:** Cloud\
**Created:** [December 26, 2016, 12:53am UTC](https://community.particle.io/t/how-to-pass-unescaped-json-to-azure-iothub/28142 "2016-12-26T00:53:11Z")\
**Showing post:** 8
**Post date:** [December 27, 2016, 10:58pm UTC](https://community.particle.io/t/how-to-pass-unescaped-json-to-azure-iothub/28142/8 "2016-12-27T22:58:59Z")
@Dave Can help clarify on the JSON string issues.
> [@svelde](#):
> Do you get separate table columns for all fields in your message or a single column named Data (filled with the escaped JSON string)?
Yes, I get separate table columns placed into the Azure Table storage and here is what my code and JSON Template look like to do that:
Here is the code I'm testing on a Photon:
```cpp
char Org[] = "My_ORGANIZATION";
char Disp[] = "Particle Photon";
char Locn[] = "Fishers, IN";
const char* cityLocation = "Fishers"; //City for my Photon
const char* stateLocation = "IN"; // State for my Photon
int SOC = 95;
float Voltage = 12.80;
float Current = 5.25;
float TTG = 35.4;
float Temperature = 81.3;
float SolarVin = 24.2;
float SolarVmp = 19.2;
float SolarW = 56.2;
// The on-board LED
int led = D7;
  pinMode(led, OUTPUT);
  char payload[255];
  // Turn the LED ON
 digitalWrite(led, HIGH);
  snprintf(payload, sizeof(payload), "{ \"s\": %d, \"v\": %.2f, \"i\": %.2f, \"t\": %.2f,\"f\": %.2f, \"s\": %.2f, \"m\": %.2f, \"w\": %.2f,\"l\":\"%s\" }", SOC, Voltage, Current, TTG, Temperature, SolarVin, SolarVmp, SolarW, Locn);
   //Serial.println(payload);
  // Spark.publish("AzureElectron", payload, NO_ACK); //The NO_ACK is currently only working with RC 0.6.0 rc1 firmware. This is just a test. For Electron
   Particle.publish("Azure_IOT_Almost", payload, PRIVATE);
  // Turn the LED off
  digitalWrite(led, LOW);
  delay(10000);
And here is how I have the Azure IoT Hub setup with custom JSON formatting to get the data fields into separate columns in Azure Table Storage:
 ![](https://us1.discourse-cdn.com/flex026/uploads/particle/original/2X/4/4293058927149714f8fbec8bd8805ef70297e528.png)
Then using this Azure Stream Analytics Query:
I get data in separate columns in the Azure Table Database:
 ![](https://community.particle.io/uploads/particle/original/2X/0/07983c73d6d6bb9d19454add2554cb569e512e78.png)
Does that help you any?
_[View the full topic](https://community.particle.io/t/how-to-pass-unescaped-json-to-azure-iothub/28142)._
