Question. I know it used to be that you could get a binary file by compiling your program in Particle Dev and then a binary file would be made in your project folder. But this is no longer the case. Is there any other way that you can retrieve that binary file?
If your build succeedes you still will get a binary file.
Maybe you are building another project folder than the one you are editing.
Another way you can get the binary from our online IDE is by pressing the following download button next to your application name:
