How to connect a 4-20ma pressure sensor to the Monitor One I/O expander card?
I have a pressure sensor that has two wires, one + the other -. How would I connect this to the Monitor One I/O extender? The Monitor One datasheet shows connecting the 24V input power, ground, and 4-20ma input to the sensor (Block diagram - I/O Card) but my sensor only has two wires. I apologize for my ignorance. The schematic of the 4-20mA INPUT appears to be shunt. Am thinking that the - wire from the sensor would connect to the 4-20ma input and the + wire of the sensor would connect to 24volts but I don't want to destroy my Monitor One. Can someone help me?
What sensor do you have? Do you have a datasheet?
Sone sensors will pull 4mA to power itself, and the rest will be the signal feedback.
This is a Brand ZGCj Model Cj-YBT sensor. Hopefully the image of the wiring diagram is here. This is my first post and just getting started with Particle devices.
I've been using it with a R Click 4-20ma module that handles the conversion and has an SPI interface.
I connected the - line to the 4-20ma input on the expansion board and + line to the 24V input and it works great. Sure would be nice to have a 3.3v to 24v on the expansion board to use with 4-20ma and 0-10V sensors as I'm looking at solar panel input which won't always be available. Maybe a 100ma max and an enable so that it could be disabled to save power when not taking readings.
That's great news!
You can easily add your own custom expansion board to accomplish this - though 24V boost converters are not as easy to come by as 12V.
I've used these before in a pinch: https://a.co/d/gzo6kDM
No Enable pin, but a MosFET could do that for you. Otherwise a boost converter from Ti or Renesas would do the trick.
Chris, Thanks for the response. I'll start with the "in a pinch" modules. For the particular sensor I'm testing with now 12V would work.
