I’m really new to programming and electronics in general.
I have prototyped something with the InternetButton and now I’m building a new hardware prototype from scratch, based on the InternetButton, plus adding a TFT LCD and other stuff.
The thing is the buzzer’s original pin (D0) is already taken by the TFT’s D/C pin and I want to avoid rewiring it.
I would like to know how can I modify the library to assign D2 as the buzzers pin instead of D0.
I can’t find it in the library. Any suggestions?
As I said before the original prototype was done using InternetButton and progressively got more complex from there. I needed a fast way o reusing all the code I already had, this was the fastest/simplest solution I could think of.
This is just a proof of concept to be shown tomorrow, eventually I’ll have to use the original libraries as you well said.
