I’ve been searching the forums trying to find a definite answer on how many sockets are available on a P0/P1 and have seen a range of answers over time. I’m currently having SOS issues because I did not properly manage my connections, so while I dig thru my code I figured it would be good to know the limit I have to work with.
Digging thru the firmware, I found the following:
#define WICED_MAXIMUM_NUMBER_OF_SOCKETS_WITH_CALLBACKS (5)
Does that mean the max is 5? Assuming the cloud connection uses 1 socket that leaves 4 sockets for application firmware? This does match up with some of the posts I’ve found.
Did I find the right section in the firmware?
