Hi, im trying to make a “control panel” for my device as a webserver. I want to have a login page, where if i i enter the correct password i will be taken to another page. However, im only shown the API call result in the browser.
Here is my code for this:
TCPClient tcpClient;
TCPServer tcpServer = TCPServer(80);
String serverIP;
bool signedIn = false;
Particle.function("authenticate",authenticate);
serverIP = WiFi.localIP();
tcpServer.begin();
tcpClient = tcpServer.available();
if (tcpClient.connected() && tcpClient.available()) {
if(!signedIn) {
showLoginPage();
if(signedIn) {
showMainPage();
else {
//Serial.println(serverIP);
int authenticate(String command) {
if(command == "123") {
Serial.println("Logged in!");
showMainPage();
} else {
Serial.println("Password is wrong!");
void showLoginPage() {
tcpClient.print("<html>");
tcpClient.print("<center><h2>Control Panel</h2></center><br>");
tcpClient.print("<center><p>Enter password</p></center>");
tcpClient.print("<form action='https://api.particle.io/v1/devices/myDeviceId/authenticate?access_token=myAccessToken' method='POST'>");
tcpClient.print("<center><input type='text' name='password' value=''></center><br>");
tcpClient.print("<center><input type='submit' value='Log in'></center>");
tcpClient.print("</form>");
tcpClient.print("</html>");
tcpClient.flush();
tcpClient.stop();
void showMainPage() {
tcpClient.print("MAINPAGE");
How can i run the showMainPage() and display its content in the browser, instead of seeing the result from the API call? Im reading it could be done with a Javascript parser? Im not too seasoned in Javascript.
Is there any other way of doing this with the Particle Cloud?
