Highlighting in the CLI Error Log
Anyone set up highlighting of the CLI Error Log? Would be super useful as I find it hard to extract the important information from the fairly sizeable logs that come through. No expert on VSCode though so I’m not sure where to begin with this
can you be more specific? are you talking about the compiler output and linking its errors to your source code? (should be happening but intellisense can be flaky) something else?
Woah you can get it to link?! That would be cool. Even just basic syntax highlighting would be nice. Here’s an example of what I’m seeing, and it’s just not that easy to extract the important information. Admittedly this one is not too bad, but if you have a load of warnings going on as well which the error is mixed up with it can be real hard to spot! Screenshot (539)|382x500
